14 years agoI cant work this out!
This is to adjust volume of incoming audio samples by just multiplying by a constant value (SW). I wanted to be able to control the volume value with the switches on the DE2 but i get no sound at all...
14 years agoCouple of points:
1. You didn't do a good job of copy/pasting because you have a signal called 'sample_reg' but you have an assignment that cannot compile:sample_out<=sample reg; -- Note the space between 'sample' and 'reg' 2. The output of the entity sample_out even if it was connected to 'sample_reg' as you no doubt intended, still has a problem in that you never assigned anything to 'sample_reg' so 'sample_out' will get set to all zeros since sample_reg is unassigned. 3. You have two assignments to sample_out. This would never make it through any synthesis tool because it would mean that there are two drivers for sample_out and the tool would end with an error. Simulation would show that there are two drivers after you scratch your head for a few minutes debugging. However, if you use std_ulogic_vector rather than std_logic_vector (similarly, use std_ulogic rather than std_logic for bits) than the simulator will flag the error during a compile as well...without having to debug anything. Since you're a beginner, I would suggest learning how to use a simulator. Once you're even mildly proficient, you will be far more productive debugging problems in a simulation environment...much more so than debugging hardware or asking on a forum (not a criticism, just a suggestion). For your current problem, you can ignore Tricky's question about why you are not using a clock for a synchronous design. Your design as posted has no need for a clock, or a process. It's fine except for the items I noted above (assuming that you did get the pin numbering correct as Tricky suggested that you verify, which you say you did). Kevin Jennings
