14 years agoI am not sure why this happen.. (process problem)
Hi. I made two same codes about BCD adder and first code is working well, but second code had a problem.The only diffence between two code is the sensitivity list. first code includes bin_resul...
14 years agoFirst remember that the quartus synthesizer ignores sensitivity lists, so both codes will in fact generate the same logic. This is only a simulation problem.
Second, the rule with sensitivity lists, when you aren't doing a clocked process, is to include in the list all the signals that you read in the process. In your case, the sensitivity list should be (bin_result). It is only by doing this that you ensure that the simulator will give the same results than a real implementation. What is happening in (2) is probably that in your test bench affects simultaneously new values to astring and bstring, and does it only once. With this linebin_result<= astring + bstring;the bin_result signal will be updated with the new value in the simulation, but only after a delta cycle. On the other hand your process will be executed on the same delta cycle that you changed the astring and bstring signals, and at this moment bin_result still has its old value.
