12 years agoHPS+PCIe project(Quartus II 13.1 64 bit),compile design--Assembler error
Info: ******************************************************************* Info: Running Quartus II 64-Bit Assembler Info: Version 13.1.0 Build 162 10/23/2013 SJ Full Version Info: Proces...
12 years ago --- Quote Start --- Info: ******************************************************************* Info: Running Quartus II 64-Bit Assembler Info: Version 13.1.0 Build 162 10/23/2013 SJ Full Version Info: Processing started: Thu Jan 09 10:46:06 2014 Info: Command: quartus_asm --read_settings_files=off --write_settings_files=off kz -c kz Warning (15104): Quartus II software detected a bonding design. Reconfiguration is not supported for Bonded designs and MIF is not created for this design. Warning (15104): Quartus II software detected a bonding design. Reconfiguration is not supported for Bonded designs and MIF is not created for this design. Warning (15104): Quartus II software detected a bonding design. Reconfiguration is not supported for Bonded designs and MIF is not created for this design. Warning (15104): Quartus II software detected a bonding design. Reconfiguration is not supported for Bonded designs and MIF is not created for this design. Info (115030): Assembler is generating device programming files Error (210006): Can't save or open file D:/work/altera_pcie_hip_ast_ed/kz_cv/db/ip/pcie_de_gen1_x4_ast64_hps/submodules/sequencer/alt_types.pre.h Error: Quartus II 64-Bit Assembler was unsuccessful. 1 error, 4 warnings Error: Peak virtual memory: 706 megabytes Error: Processing ended: Thu Jan 09 10:46:25 2014 Error: Elapsed time: 00:00:19 Error: Total CPU time (on all processors): 00:00:18 Error (293001): Quartus II Full Compilation was unsuccessful. 3 errors, 791 warnings screenshots: http://www.alteraforum.com.cn/attachment.aspx?attachmentid=1377 http://www.alteraforum.com.cn/attachment.aspx?attachmentid=1378 The alt_types.pre.h file is exist. Anyone any suggestions on how to solve the problem ? Thanks PS: alt_types.pre.h file;
#ifndef __alt_types_h__
#define __alt_types_h__
* don't declare these typedefs if this file is included by assembly source.
#ifndef alt_asm_src
typedef signed char alt_8;
typedef unsigned char alt_u8;
typedef signed short alt_16;
typedef unsigned short alt_u16;
typedef signed long alt_32;
typedef unsigned long alt_u32;
typedef long long alt_64;
typedef unsigned long long alt_u64;
#endif
#define alt_inline __inline__
#define alt_always_inline __attribute__ ((always_inline))
#define alt_weak __attribute__((weak))
#endif /* __alt_types_h__ */ --- Quote End --- The issue for me at least is that I was using the *.qsys file in my file list. Apparently you should instead use the *.qjp file from within the generated system hierarchy in the synthesis directory: pcie_de_gen1_x4_ast64_hps/synthesis/pcie_de_gen1_x4_ast64_hps.qjp
