9 years agoHPS DDR3 in Cyclone V
Hello, Suppose we have a properly designed PCB with a Cyclone V SOC and DDR3 (routed to the HPS pins). I know that the HPS part is be able to load properly without any FPGA logic programmed a...
9 years ago --- Quote Start --- I assume that your preloader has been loaded onto the SD Card/QSPI and you did not change/modify it. Thus, even if you recompile your design for the FPGA, as long as the preloader remains untouched, the HPS DDR3 calibration will still be successful --- Quote End --- That's correct. So even if I program the FPGA with a new RBF - as long as I don't update the files on the SD card - the newer SDRAM parameters won't take effect ? I.E: these SDRAM parameters aren't manifested in the RBF in any way ?
