13 years agoHPS clock peripherals, specifically CAN
How do I determine the clock frequency of the HPS peripherals and edit them? In particular the CAN controller clock, can_clk. And I guess also, l4_sp_clk, since the CAN controller uses both these clo...
12 years agoI have a similar problem: where takes the bsp-editor the settings for generating the pll_config.h. It seams to me, that it will use a default for the all Devices, but what if I use a Device with lower speedgrade, (e.g. The Cyclon V of the SocKit Board from Arrow ). Have I always modify after each generation the pll_config.h by hand?
