13 years agoHPS clock peripherals, specifically CAN
How do I determine the clock frequency of the HPS peripherals and edit them? In particular the CAN controller clock, can_clk. And I guess also, l4_sp_clk, since the CAN controller uses both these clo...
13 years agoBy preloader generator tools, do you mean the bsp-editor? If so I don't see the options in the GUI (windows btw) for setting the frequencies, but when creating a new bsp using the editor it does generate pll_config.h which allows me to edit the clock frequencies. I am not exactly sure what steps I need to go from here with the generated files.
