15 years agoHPCII ddr2 controller
Hi, I generated HPCII ddr2 controller using megawizard. I included the module in my fpga design and trying to run simulation. I dont see the local_init_done signal going high at all. As per the do...
15 years agoYou have to keep the write_req hight for the size of the transfer. The burst start must stay high only for the first cycle.
Also you need to check if the ready signal is high when initialising a burst. Look at the timing diagramm in the UG of the DDR HP Ctrl.
