17 years agohowto use LEs insted of M9K?
Hi, I'm using a UART 16550 core from opencores in the SOPC builder, works very fine. It has build-in rx/tx FIFO, 16 Byte each. Quartus II uses a whole M9K-Block, which means a lot of wasted RAM. M...
17 years agoIf you use the megawizard to instantiate a ram, rather than inferring it, there is a tick box which allows to choose LEs or M9Ks.
