12 years agoHow to write data into DDR3 SDRAM-HPS!
Hi everyone! I create Qsys to connect SDRAM/FPGA that saves data of camera with HPS. I will read this data by arm through H2F AXI Bridge and send it to VGA. I use 2 components: "Frame Reader" and ...
12 years ago --- Quote Start --- It is definitely possible. However, you need to use the HPS-FPGA axi bus and not the lightweight axi bus for higher data throughput. --- Quote End --- Hi WH2011! I think I will use 3 bridges: + Lightweight axi: this only use to control Frame Reader + HPS-FPGA Bridge: I will use this bridge to read data from DDR3-FPGA to save to DDR3-HPS + FPGA-HPS Bridge: Frame Reader will be connected with this bridge to read data from DDR3-HPS and output to VGA Now, I am doing this project, but I have a problem when using arm to read data from DDR3-FPGA and Frame Reader read data from DDR3-HPS and output to VGA. Do you give me a direction for me Sorry if I disturb you! BR,
