12 years agoHow to write data into DDR3 SDRAM-HPS!
Hi everyone! I create Qsys to connect SDRAM/FPGA that saves data of camera with HPS. I will read this data by arm through H2F AXI Bridge and send it to VGA. I use 2 components: "Frame Reader" and ...
12 years agoIt is definitely possible. However, you need to use the HPS-FPGA axi bus and not the lightweight axi bus for higher data throughput.
