15 years agoHow to use the DCFIFO?
Hello i used the megawizard to instantiate a DCFIFO but it seems i can't write anything to the fifo.. my usedw never changes Anyone has a verilog example of a code that is working??? I tried to...
15 years agoHi,
dc fifo is straightforward and doesn't need any particular sequences. reset is not done by many people. I note that you connect to usedw two signals (write and read word counts). This should result in eror or warning at compilation(double drive). You should not do that
