15 years agoHow to use the DCFIFO?
Hello i used the megawizard to instantiate a DCFIFO but it seems i can't write anything to the fifo.. my usedw never changes Anyone has a verilog example of a code that is working??? I tried to...
15 years ago --- Quote Start --- My assumption is that your fifo gets full. When the fpga starts and soon after reset, you are writing into the fifo without reading thus it gets full and the word count will increase from 0 to 128. When 128 the word count cannot represent 128 and rolls back to zero unless you have one extra bit on your word count. The best way is to simulate your design or trigger the signaltap when fifo words is say half (bit[5] '0' => '1') --- Quote End --- I will take a look into that, but my C program is reading the USEDW[2] in pooling mode, if that was the problem it should read 1 constantly instead of 0, right?
