EEren
4 years agoHow to use only one channel on ADC port Max10
I have an ADC core
component adc_qsys is
port (
adc_1_command_valid : in std_logic := '0'; -- adc_1_command.valid
adc_1_command_channel : in...
EEren
4 years agoSorry, I failed to understand. How DCLK pin related to ADC pins? And where do I change this configuration to Active Serial?
As I see in MAX10 Configuration Scheme may be only - Internal Configuration. It's an on board flash in the device.
EEren
4 years agoWell... I found the answer - If you use bank 1A for ADC, you cannot use the bank for GPIO.
At least something stays rock solid - the support is traditionally lame on the forum.
