12 years agoHow to use Memory
Hi, I need some help
I want to receive data on online to the FPGA Board, so I should use memory as I know. the problem is I haven't my own board, so I should prepare to apply the code in the board in only one day, for that I need some guiding. how can I put the data in RAM (is it from Interface), what acquaintances should I have to go in coding with the min problem thank you,greetings3 Replies
You question isnt very clear
What interface are you using? What will the FPGA board be? how much data? whats the data rate? whats the application? You need to specify what you need, and ask more specific questions. - Altera_Forum
--- Quote Start --- You question isnt very clear What interface are you using? What will the FPGA board be? how much data? whats the data rate? whats the application? --- Quote End --- I didn't get that level yet, to make an own decision to choose the interface I want from the FPGA to receive online data (image) without PC Application in biometric recognition --- Quote Start --- You need to specify what you need, and ask more specific questions. --- Quote End --- I need to know what I should to study (I'm begginer ^_^) - Altera_Forum
OK
where your data from is your FPGA? so FPGA creates image data? not even image sensor? where your data to is ... online? what do you mean online? without PC? do you mean show those images on VGA monitor directory? anyway can you say what kind of board do you use? DE0? / NEEK? / your own design? see you.
