11 years agoHow to use M25P32 ?
Hi guys, I want to use M25P32 in my design for its low cost. But unfortunately, it can't be recognized by Quartus programmer. It also can't be opened with the function "alt_flash_open_dev". ...
11 years agoHow are you trying to access it with the Quartus programmer? Via a dedicated AS programming header? Or indirectly via JTAG? Do you have either or (hopefully) both of these programming headers on your hardware? With a little more detail I think we should be able to make that bit work.
Getting 'alt_flash_open_dev' working may be a little more involved but lets make sure you're hardware is working with the above step first. Cheers, Alex
