14 years agoHow to use an EPCS Flash
Hallo together, I'm actually trying to save data from NIOS II into an EPCS64 device. My system contains an EPCS controller. But now the confusion is complete, there are so many files for usin...
14 years agoALTERA_AVALON_EPCS_FLASH_CONTROLLER_INSTANCE is a macro that create static structure var for epcs device.
The behaviour you described is quite strange... I can't explain it... It still seems that all init following last TIMER init are empty... :confused: Try calling INSTANCE and INIT macro later in main().
