14 years agoHow to use an EPCS Flash
Hallo together, I'm actually trying to save data from NIOS II into an EPCS64 device. My system contains an EPCS controller. But now the confusion is complete, there are so many files for usin...
14 years ago --- Quote Start --- I forgot to give maybe an important information, my flash device is no original altera epcs flash! Could I access such an flash with an epcs controller? --- Quote End --- Then probably the hal driver is simply not recognizing the device id. What device are you using? I think you need to modify altera_avalon_epcs_flash_controller.c, adding the specific signature of your flash.
