14 years agohow to understand some note in an477
Hi, I have some confuse about how to interface a IO referenced by vccio1.8V with a external 3.3V driver. Quoted from the note#2 of table 1 in an477, “Other I/O standards do not require attent...
14 years agoI guess you are referring to AN447?
The document's main concern is keeping safe input voltages for FPGAs. Driving a FPGA by 3.3V logic is a critical case from it's viewpoint. Using correct source side serial termination there's should be no problem. Previous FPGA families had "Multi-IO" voltage tables saying 3.3V can drive 1.5 to 3.3V CMOS on input. The input overdriving aspect involves a rather asymmetrical threshold and a certain delay asymmetry. You should also care for a reliable low level. If delay symmetry is an objective, you can think about using voltage dividers as level translaters.
