14 years agohow to turn seconds into h:m:s???
for example: "56783"seconds turn into the format of "h:m:s" is "15:46:23". I used the method of comparasion,i.e.confirm the hours first, 15*3600 < 56783 < 16*3600,so I confim the hour is 15. ...
14 years agoIn vhdl, you can run multiple counters on the 1 sec clock edge:
if(Seconds /= 59) then
Seconds <= Seconds + 1;
else
Seconds <= (others => '0');
if(Minutes /= 59) then
Minutes <= Minutes + 1;
else
Minutes <= (others => '0');
if(Hours /=23) then
Hours <= Hours + 1;
else
Hours <= (others => '0');
end if;
end if;
end if;
