14 years agoHow to turn off all output port of MAXII during power-on.
How to turn off all output port of MAXII during power-on. When power is turned on, some output pins of MAXII device have signals. This has some negative effect on circuit, and sometimes, MAXII is bur...
14 years agoAs clearly documented in the device manual, MAX II I/O-pins are configured as input with weak pull-up during power up. Presumed the specification is correct, you'll see a positive pulse generated by the pull-up resistors during power-on reset. It's basically the same state that you'll observe for an unconfigured device.
If the assumption is right, there are two points to mention. - There's absolutely no problem of collision involved with weak pull-up resistors. - Weak pull-ups may be still a problem with active high output pins that are activating some function unintentionally. In this case you should either change the logic to active low or place external pull-down resistors overriding the weak pull-ups, e.g. 1k. Regards, Frank
