How to transmit video data to DDR and display ?
Hi there,
Good day.
We would like to suggest you to use the frame buffer instead of MGDMA.
Frame buffer is for moving video from/to DDR.
You may setup your connection as below:
Test Pattern Generator (TPG)-->Frame buffer---> CVO (Clock Video Output)-->HDMI TX.
You may refer to below document. In this document states what is the function of frame buffer, types of connection, parameter settings, application examples and more:
Hope this answers your question.
Thank you.
ZH_Intel
- 22584322 years ago
Hello ZH_Intel,
Thanks for your assistance.
Following your instructions, I've successfully used the frame buffer, and now the video is displaying properly. Additionally, I've used memtool in Linux to check DDR3, and confirmed that the frame buffer is writing data into DDR3.
My purpose is to send this video data to a second Cyclone V SoC and display the video there. My initial plan was to use MSGDMA to transfer the video data generated by TPG to DDR3 first, and then send this data through Ethernet in Linux. The second SoC would then receive the video data and display it.
If I'm using the frame buffer, how can I send the video data out?
thanks again for your assistance.
Best regards.
