RLedu
4 years agoHow to test HPS-FPGA project with time limited sof
Hello dear community,
I am currently working on a project using a licensed IP (JESD204B) controlled through HPS that I didn't buy yet, but I do have the evaluation IP. This leads to get a time li...
aikeu
4 years agoHi RLedu,
I may not understand correctly the part of you question, would like to clarify with you on that.
You mentioned that the Linux freeze when you are programming the QSPI?
What is the scenario that when freezing happened?
This only happened when you work with that particular IP?
What type of file that you are programming into the board(etc .sof)?
Aik Eu
