18 years agoHow to synchronize divided PLL outputs?
I'm working on a system with multiple Stratix III devices on it. There is a master clock feeding each one, say 10ns period, and each FPGA creates some divided down clocks(all powers of 2). The pro...
18 years agoHello Rysc,
don't know if the question is still pending? I think, the most simple solution for synchronizing derived clocks between indepent PLLs is to distribute the slowest rather than the fastests clock. Consider a PLLs having /2, /4.. /16 divided outputs. If the /16 clock phase matches, all other also do. Don't know if this solution applicable for your design. I have e. g. a distributed system with different communication channels: a 20 MHz SPI and multichannel 400 MHz LVDS. All clocks are derived from a 20 MHz clock distributed by master FPGA. Regards, Frank
