9 years agoHow to switch arria10 calibration clock from usrclk pin to internal_osc?
Hi.
On our arria10 board, there is a mistake to make usrclk pin to be one DDR3's DQ pin. This would lead to transceiver not be able to be calibrated at POR and in user-mode. We got one tcl script, which is expected to transfer the calibration clock source from usrclk pad to internal_osc. But there would be error when it's executed. We check and found there are several process function that can not be able to be recongnized by quartus_sh, such as load_devices, open_sof, write_sof. Can anyone answer it? Or how to execute it? Is there something wrong? The following is the script: proc main_run {} { global argv set projName [ lindex $argv 1 ] load_package asm2 load_devices set sofName "output_files/$projName.sof"; # set sofName "$projName.sof"; set handle -1 set handle [ open_sof $sofName ] if { $handle >= 0 } { set_attribute $handle hssi_aux_0_1 xaux/pma_aux_clock_select PMA_AUX_CLOCK_SELECT_INTOSC set_attribute $handle hssi_aux_1_1 xaux/pma_aux_clock_select PMA_AUX_CLOCK_SELECT_INTOSC set_attribute $handle hssi_aux_0_0 xaux/pma_aux_clock_select PMA_AUX_CLOCK_SELECT_INTOSC set_attribute $handle hssi_aux_1_0 xaux/pma_aux_clock_select PMA_AUX_CLOCK_SELECT_INTOSC set_attribute $handle hssi_aux_0_0 xmcu/pm_uc_no_nios/pm_uc_config_wrapper/pm_uc_clksel_osc CB_INTOSC set_attribute $handle hssi_aux_0_0 xmcu/pm_uc_no_nios/pm_uc_config_wrapper/pm_uc_clkdiv_sel DIV4 set_attribute $handle hssi_aux_1_0 xmcu/pm_uc_no_nios/pm_uc_config_wrapper/pm_uc_clksel_osc CB_INTOSC set_attribute $handle hssi_aux_1_0 xmcu/pm_uc_no_nios/pm_uc_config_wrapper/pm_uc_clkdiv_sel DIV4 write_sof $handle $sofName } else { puts stderr "Failed to open sof file $sofName" } } main_runNo RepliesBe the first to reply
