How to stop Avalon DMA?
Hi @MehmetFide,
Thanks for your reply.
We cannot intervene when the DMA operation is in the process.
To shorten the time to wait for a DMA operation, you may try to reduce the number of dword for one DMA operation, so that for each DMA operation it takes less time to complete the transfer. And, in between each DMA operation, add some code at the user application level to exit the loop before the next DMA operation starts.
VenTing_Intel
Hi @ventt ,
Even If I set the number of the dword size of the DMA to be transferred to 1, the DMA will wait forever until that dword became available in the FIFO because of WaitRequest control between FIFO and DMA. The FIFO may not have amount of data requested by the DMA when we initiate the DMA at the first place. Therefore we need to be able to cancel active DMA operation to make the DMA usable again.
