MehmetFide
2 years agoHow to stop Avalon DMA?
Hello, We have an NXP SoM module (with Linux) connected to an Intel Arria 10 FPGA through a PCIe bus. We use Arria 10 Avalon-MM DMA Interface to transfer data from FPGA to our Linux processor. The ...
MehmetFide
2 years agoHi @ventt,
Thank you for your response. I went through the link you provided and followed the way suggested.
In the Linux kernel code, I have found following api which reset the secondary bus according to the PCIe standard and then wait for secondary bus to be ready again:
void pci_reset_secondary_bus(struct pci_dev *dev) { u16 ctrl; pci_read_config_word(dev, PCI_BRIDGE_CONTROL, &ctrl); ctrl |= PCI_BRIDGE_CTL_BUS_RESET; pci_write_config_word(dev, PCI_BRIDGE_CONTROL, ctrl); /* * PCI spec v3.0 7.6.4.2 requires minimum Trst of 1ms. Double * this to 2ms to ensure that we meet the minimum requirement. */ msleep(2); ctrl &= ~PCI_BRIDGE_CTL_BUS_RESET; pci_write_config_word(dev, PCI_BRIDGE_CONTROL, ctrl); } /** * pci_bridge_wait_for_secondary_bus - Wait for secondary bus to be accessible * @dev: PCI bridge * @reset_type: reset type in human-readable form * * Handle necessary delays before access to the devices on the secondary * side of the bridge are permitted after D3cold to D0 transition * or Conventional Reset. * * For PCIe this means the delays in PCIe 5.0 section 6.6.1. For * conventional PCI it means Tpvrh + Trhfa specified in PCI 3.0 section * 4.3.2. * * Return 0 on success or -ENOTTY if the first device on the secondary bus * failed to become accessible. */ int pci_bridge_wait_for_secondary_bus(struct pci_dev *dev, char *reset_type) { struct pci_dev *child; int delay; if (pci_dev_is_disconnected(dev)) return 0; if (!pci_is_bridge(dev)) return 0; down_read(&pci_bus_sem); /* * We only deal with devices that are present currently on the bus. * For any hot-added devices the access delay is handled in pciehp * board_added(). In case of ACPI hotplug the firmware is expected * to configure the devices before OS is notified. */ if (!dev->subordinate || list_empty(&dev->subordinate->devices)) { up_read(&pci_bus_sem); return 0; } /* Take d3cold_delay requirements into account */ delay = pci_bus_max_d3cold_delay(dev->subordinate); if (!delay) { up_read(&pci_bus_sem); return 0; } child = list_first_entry(&dev->subordinate->devices, struct pci_dev, bus_list); up_read(&pci_bus_sem); /* * Conventional PCI and PCI-X we need to wait Tpvrh + Trhfa before * accessing the device after reset (that is 1000 ms + 100 ms). */ if (!pci_is_pcie(dev)) { pci_dbg(dev, "waiting %d ms for secondary bus\n", 1000 + delay); msleep(1000 + delay); return 0; } /* * For PCIe downstream and root ports that do not support speeds * greater than 5 GT/s need to wait minimum 100 ms. For higher * speeds (gen3) we need to wait first for the data link layer to * become active. * * However, 100 ms is the minimum and the PCIe spec says the * software must allow at least 1s before it can determine that the * device that did not respond is a broken device. Also device can * take longer than that to respond if it indicates so through Request * Retry Status completions. * * Therefore we wait for 100 ms and check for the device presence * until the timeout expires. */ if (!pcie_downstream_port(dev)) return 0; if (pcie_get_speed_cap(dev) <= PCIE_SPEED_5_0GT) { u16 status; pci_dbg(dev, "waiting %d ms for downstream link\n", delay); msleep(delay); if (!pci_dev_wait(child, reset_type, PCI_RESET_WAIT - delay)) return 0; /* * If the port supports active link reporting we now check * whether the link is active and if not bail out early with * the assumption that the device is not present anymore. */ if (!dev->link_active_reporting) return -ENOTTY; pcie_capability_read_word(dev, PCI_EXP_LNKSTA, &status); if (!(status & PCI_EXP_LNKSTA_DLLLA)) return -ENOTTY; return pci_dev_wait(child, reset_type, PCIE_RESET_READY_POLL_MS - PCI_RESET_WAIT); } pci_dbg(dev, "waiting %d ms for downstream link, after activation\n", delay); if (!pcie_wait_for_link_delay(dev, true, delay)) { /* Did not train, no need to wait any further */ pci_info(dev, "Data Link Layer Link Active not set in 1000 msec\n"); return -ENOTTY; } return pci_dev_wait(child, reset_type, PCIE_RESET_READY_POLL_MS - delay); }
But whole those mechanisms require about 1.5sec to be completed which is not acceptable for our system.
Isn't there a command/way on the FPGA side just to terminate active Avalon DMA transaction rather then resetting whole PCIe subsystem?
Thank you.
