16 years ago
How to solve the error: "register does not hold its value outside the clock edge
I'm a beginner in VHDL. I encounter this error when trying to complile my vhdl. Below is my vhdl code that cause the error:
DataHoldRegister_temp_process3 : PROCESS (clk, reset)
BEGIN
IF reset = '1' THEN
regout <= (OTHERS => '0');
ELSIF clk'event AND clk = '1' THEN
IF enb_128_128_1 = '1' THEN
regout <= muxout;
END IF;
END IF;
END PROCESS DataHoldRegister_temp_process3;
Upsample_out1 <= muxout WHEN ( enb_128_128_1 = '1' ) ELSE
regout;
s_1 <= std_logic_vector(Upsample_out1);
s_2 <= signed(Digital_Filter1_out1);
Gain3_gainparam <= '1';
test_gain3: process(Compare_To_Zero_out1) is
begin
if Compare_To_Zero_out1 = '1' then
Gain3_out1 <= "010000000000000000";
elsif Compare_To_Zero_out1 = '0' then
Gain3_out1 <= "110000000000000000";
end if;
end process test_gain3;
sub_cast <= resize(s_2, 18);
sub_cast_1 <= Gain3_out1;
sub_temp <= resize(sub_cast, 19) - resize(sub_cast_1, 19);
Sum_out1 <= sub_temp(17 DOWNTO 0);
s_3 <= std_logic_vector(Sum_out1);
s_4 <= signed(Integrator2_out1);
Gain_gainparam <= '1';
test_gain: process(Compare_To_Zero_out1) is
begin
if compare_to_zero_out1 = '1' then
gain_out1 <= "00101001011100001010";
elsif compare_to_zero_out1 = '0' then
gain_out1 <= "11010110100011110110";
end if;
end process test_gain;
The error:
Error (10818): Can't infer register for "Gain_out1[0]" at sub.vhd(244) because it does not hold its value outside the clock edge.
Any suggestions to solve the problem?
    What is "compare_to_zero_out1"?
    Basically, I cant see any problem with your code.
    Actually, just had a thought - instead of having:
    Gain_out1 <= "11010110100011110110";
    end if;
    try this instead:
    else
    end if;
    To clarify, that you don't intend to build registers, you can use a conditional assignment instead,
    you also don't need a process for it, 6 lines of code saved.
    Gain_out1 <= "00101001011100001010" WHEN Compare_To_Zero_out1 = '1'
    ELSE "11010110100011110110";
