16 years agoHow to simulate serdes in modelsim? Which files must I compile?
16 years agoI complied the foloowing files in the eda/sim_lib file folder:
"arriagx_hssi_atoms.v" "220model.v" "altera_mf.v" "altera_primitives.v" "arriagx_atoms.v" when simulate , the system give me the following error message: # ** Error: (vsim-3033) I:/0623/FPGA_75M/IPCORE/xcvr_s16.v(203): Instantiation of 'alt2gxb' failed. The design unit was not found.# Region: /testbench_trx/RX/b2v_inst6# Searched libraries:# work I compiled the quartus/libraries/megafunctions/alt2gxb.v vlog -reportprogress 300 -work work D:/altera/90/quartus/libraries/megafunctions/alt2gxb.v# Model Technology ModelSim SE vlog 6.2b Compiler 2006.07 Jul 31 2006# -- Compiling module alt2gxb# -- Compiling module nfts_recovery_ip# -- Compiling module electrical_idle_detector# -- Compiling module ltd_counter# -- Compiling module ltr_ltd_fsm# -- Compiling module wait_counter# -- Compiling module nfts_os_detector simulate, it gives the error message: # ** Error: (vsim-3033) D:/altera/90/quartus/eda/sim_lib/stratixiigx_hssi_atoms.v(22225): Instantiation of 'oper_add' failed. The design unit was not found.# Region: /testbench_trx/TX/b2v_inst6/alt2gxb_component/channel_rec[0]/genblk1/genblk6/receive/digi_rx_1/comp_chnl_top_1# Searched libraries:# work# ** Error: (vsim-3033) D:/altera/90/quartus/eda/sim_lib/stratixiigx_hssi_atoms.v(22237): Instantiation of 'oper_add' failed. The design unit was not found.# Region: /testbench_trx/TX/b2v_inst6/alt2gxb_component/channel_rec[0]/genblk1/genblk6/receive/digi_rx_1/comp_chnl_top_1# Searched libraries:# work# ** Error: (vsim-3033) D:/altera/90/quartus/eda/sim_lib/stratixiigx_hssi_atoms.v(22249): Instantiation of 'oper_add' failed. The design unit was not found.# Region: /testbench_trx/TX/b2v_inst6/alt2gxb_component/channel_rec[0]/genblk1/genblk6/receive/digi_rx_1/comp_chnl_top_1# Searched libraries:# work# ** Error: (vsim-3033) D:/altera/90/quartus/eda/sim_lib/stratixiigx_hssi_atoms.v(22261): Instantiation of 'oper_add' failed. The design unit was not found.# Region: /testbench_trx/TX/b2v_inst6/alt2gxb_component/channel_rec[0]/genblk1/genblk6/receive/digi_rx_1/comp_chnl_top_1# Searched libraries:# work# ** Error: (vsim-3033) D:/altera/90/quartus/eda/sim_lib/stratixiigx_hssi_atoms.v(22273): Instantiation of 'oper_add' failed. The design unit was not found.# Region: /testbench_trx/TX/b2v_inst6/alt2gxb_component/channel_rec[0]/genblk1/genblk6/receive/digi_rx_1/comp_chnl_top_1# Searched libraries:# work# ** Error: (vsim-3033) D:/altera/90/quartus/eda/sim_lib/stratixiigx_hssi_atoms.v(22285): Instantiation of 'oper_add' failed. The design unit was not found.# Region: /testbench_trx/TX/b2v_inst6/alt2gxb_component/channel_rec[0]/genblk1/genblk6/receive/digi_rx_1/comp_chnl_top_1# Searched libraries:# work# ** Error: (vsim-3033) D:/altera/90/quartus/eda/sim_lib/stratixiigx_hssi_atoms.v(22297): Instantiation of 'oper_add' failed. The design unit was not found.# Region: /testbench_trx/TX/b2v_inst6/alt2gxb_component/channel_rec[0]/genblk1/genblk6/receive/digi_rx_1/comp_chnl_top_1# Searched libraries:# work# ** Error: (vsim-3033) D:/altera/90/quartus/eda/sim_lib/stratixiigx_hssi_atoms.v(22309): Instantiation of 'oper_add' failed. The design unit was not found.# Region: /testbench_trx/TX/b2v_inst6/alt2gxb_component/channel_rec[0]/genblk1/genblk6/receive/digi_rx_1/comp_chnl_top_1# Searched libraries:# work# ** Error: (vsim-3033) D:/altera/90/quartus/eda/sim_lib/stratixiigx_hssi_atoms.v(22318): Instantiation of 'oper_decoder' failed. The design unit was not found.# Region: /testbench_trx/TX/b2v_inst6/alt2gxb_component/channel_rec[0]/genblk1/genblk6/receive/digi_rx_1/comp_chnl_top_1# Searched libraries:# work# ** Error: (vsim-3033) D:/altera/90/quartus/eda/sim_lib/stratixiigx_hssi_atoms.v(22325): Instantiation of 'oper_decoder' failed. The design unit was not found.# Region: /testbench_trx/TX/b2v_inst6/alt2gxb_component/channel_rec[0]/genblk1/genblk6/receive/digi_rx_1/comp_chnl_top_1# Searched libraries:# work# ** Error: (vsim-3033) D:/altera/90/quartus/eda/sim_lib/stratixiigx_hssi_atoms.v(22332): Instantiation of 'oper_decoder' failed. The design unit was not found.# Region: /testbench_trx/TX/b2v_inst6/alt2gxb_component/channel_rec[0]/genblk1/genblk6/receive/digi_rx_1/comp_chnl_top_1# Searched libraries:# work# ** Error: (vsim-3033) D:/altera/90/quartus/eda/sim_lib/stratixiigx_hssi_atoms.v(22339): Instantiation of 'oper_decoder' failed. The design unit was not found.# Region: /testbench_trx/TX/b2v_inst6/alt2gxb_component/channel_rec[0]/genblk1/genblk6/receive/digi_rx_1/comp_chnl_top_1# Searched libraries:# work# ** Error: (vsim-3033) D:/altera/90/quartus/eda/sim_lib/stratixiigx_hssi_atoms.v(22346): Instantiation of 'oper_decoder' failed. The design unit was not found.# Region: /testbench_trx/TX/b2v_inst6/alt2gxb_component/channel_rec[0]/genblk1/genblk6/receive/digi_rx_1/comp_chnl_top_1# Searched libraries:# work# ** Error: (vsim-3033) D:/altera/90/quartus/eda/sim_lib/stratixiigx_hssi_atoms.v(22353): Instantiation of 'oper_decoder' failed. The design unit was not found.# Region: /testbench_trx/TX/b2v_inst6/alt2gxb_component/channel_rec[0]/genblk1/genblk6/receive/digi_rx_1/comp_chnl_top_1# Searched libraries:# work# ** Error: (vsim-3033) D:/altera/90/quartus/eda/sim_lib/stratixiigx_hssi_atoms.v(22360): Instantiation of 'oper_decoder' failed. The design unit was not found.# Region: /testbench_trx/TX/b2v_inst6/alt2gxb_component/channel_rec[0]/genblk1/genblk6/receive/digi_rx_1/comp_chnl_top_1# Searched libraries:# work# ** Error: (vsim-3033) D:/altera/90/quartus/eda/sim_lib/stratixiigx_hssi_atoms.v(22367): Instantiation of 'oper_decoder' failed. The design unit was not found.# Region: /testbench_trx/TX/b2v_inst6/alt2gxb_component/channel_rec[0]/genblk1/genblk6/receive/digi_rx_1/comp_chnl_top_1# Searched libraries:# work# ** Error: (vsim-3033) D:/altera/90/quartus/eda/sim_lib/stratixiigx_hssi_atoms.v(22374): Instantiation of 'oper_decoder' failed. The design unit was not found.# Region: /testbench_trx/TX/b2v_inst6/alt2gxb_component/channel_rec[0]/genblk1/genblk6/receive/digi_rx_1/comp_chnl_top_1# Searched libraries:# work# ** Error: (vsim-3033) D:/altera/90/quartus/eda/sim_lib/stratixiigx_hssi_atoms.v(22381): Instantiation of 'oper_decoder' failed. The design unit was not found.# Region: /testbench_trx/TX/b2v_inst6/alt2gxb_component/channel_rec[0]/genblk1/genblk6/receive/digi_rx_1/comp_chnl_top_1# Searched libraries:# work# ** Error: (vsim-3033) D:/altera/90/quartus/eda/sim_lib/stratixiigx_hssi_atoms.v(22388): Instantiation of 'oper_decoder' failed. The design unit was not found.# Region: /testbench_trx/TX/b2v_inst6/alt2gxb_component/channel_rec[0]/genblk1/genblk6/receive/digi_rx_1/comp_chnl_top_1# Searched libraries: .......... .........and there are also many error messages , for the space limited, I cannot list all of them. perhaps some of the files i have not compiled . which files , i am appreciative if some one can give me some advices.
