12 years ago
How to share one PLL and DLL by two DDR3 interfaces
Hi Folks,
I have a Cyclone V GX FPGA Development Board. There are six DDR3 components on the board, three are on the bottom side of 5CGXFC7D6F31C7NES and the others are on the right side. Now I'm gonna use a bottom ddr3 component and a right ddr3 component and I want the two DDR3 interfaces can share one PLL and one DLL.
My Quartus II Version is 13.1 and Both the DDR3 interfaces operate at 300MHz in the half-rate mode.
It is possible accroding to emi.pdf
https://www.alteraforum.com/forum/attachment.php?attachmentid=8937
My design meets the above criteria. But when Quartus II compils My design, there are sereval errors reported by Fitter.
Error (175001): Could not place dual-regional clock driver
Info (175028): The dual-regional clock driver name: ddr3_inf1:ddr3_master|ddr3_inf1_0002:ddr3_inf1_inst|ddr3_inf1_pll0:pll0|pll_addr_cmd_clk~CLKENA0
Error (177002): The Fitter could not use locations for destination pin that were in the same clock region as the dual-regional clock driver
Info (175027): Destination: pin mem1_cke[0]
Info (175015): The I/O pad is constrained to the location PIN_L28 due to: User Location Constraints (PIN_L28)
Info (175029): 136 locations affected
Info (175029): CLKCTRL_R64 and CLKCTRL_R82
Info (175029): CLKCTRL_R64 and CLKCTRL_R83
Info (175029): CLKCTRL_R64 and CLKCTRL_R84
Info (175029): CLKCTRL_R64 and CLKCTRL_R85
Info (175029): CLKCTRL_R64 and CLKCTRL_R86 Info (175029): CLKCTRL_R64 and CLKCTRL_R87
Info (175029): CLKCTRL_R65 and CLKCTRL_R82
Info (175029): CLKCTRL_R65 and CLKCTRL_R83
Info (175029): CLKCTRL_R65 and CLKCTRL_R84
Info (175029): CLKCTRL_R65 and CLKCTRL_R85
Info (175029): CLKCTRL_R65 and CLKCTRL_R86
Info (175029): CLKCTRL_R65 and CLKCTRL_R87
Info (175029): and 124 more locations not displayed
Info (175027): Destination: pin mem1_a[7] Info (175015): The I/O pad is constrained to the location PIN_AC30 due to: User Location Constraints (PIN_AC30)
Info (175029): 100 locations affected
Info (175029): CLKCTRL_R0 and CLKCTRL_R10
Info (175029): CLKCTRL_R0 and CLKCTRL_R11
Info (175029): CLKCTRL_R0 and CLKCTRL_R12
Info (175029): CLKCTRL_R0 and CLKCTRL_R13
Info (175029): CLKCTRL_R0 and CLKCTRL_R14
Info (175029): CLKCTRL_R0 and CLKCTRL_R15
Info (175029): CLKCTRL_R0 and CLKCTRL_R16
Info (175029): CLKCTRL_R0 and CLKCTRL_R17
Info (175029): CLKCTRL_R0 and CLKCTRL_R18
Info (175029): CLKCTRL_R0 and CLKCTRL_R19
Info (175029): CLKCTRL_R1 and CLKCTRL_R10
Info (175029): CLKCTRL_R1 and CLKCTRL_R11
Info (175029): and 88 more locations not displayed
Info (175027): Destination: pin mem2_a[10] Info (175015): The I/O pad is constrained to the location PIN_AJ8 due to: User Location Constraints (PIN_AJ8)
Info (175029): 36 locations affected Info (175029): CLKCTRL_R70 and CLKCTRL_R76
Info (175029): CLKCTRL_R70 and CLKCTRL_R77
Info (175029): CLKCTRL_R70 and CLKCTRL_R78
Info (175029): CLKCTRL_R70 and CLKCTRL_R79
Info (175029): CLKCTRL_R70 and CLKCTRL_R70
Info (175029): CLKCTRL_R70 and CLKCTRL_R71
Info (175029): CLKCTRL_R71 and CLKCTRL_R76
Info (175029): CLKCTRL_R71 and CLKCTRL_R77
Info (175029): CLKCTRL_R71 and CLKCTRL_R78
Info (175029): CLKCTRL_R71 and CLKCTRL_R79
Info (175029): CLKCTRL_R71 and CLKCTRL_R70
Info (175029): CLKCTRL_R71 and CLKCTRL_R71
Info (175029): and 24 more locations not displayed
Error (12289): An error occurred while applying the periphery constraints. Review the offending constraints and rerun the Fitter.
I can not find the correspoding solutions in the emi.pdf and Cyclone V handbook, so I upload the project file for help. Any help would be appreciated.
-spectrum
1 Reply
    First, I have to admit that I haven't been checking your QAR out. I just wanted to check if you have tried to assign the clock signal to a global net rather than a dual-regional one. Maybe you have selected to use an interface on the bottom left together with an interface on the top right?
    J
