PHuan25
7 years agoHow to setup 4ch 25g ethernet in one bank in stratix 10 L-tile?
I had setup 2ch 25g ethernet in one bank in stratix 10 successfully. But when I want to setup 4ch, it always recognized 2ch only.
I follow the spec. to config two ATX PLL ip for Main and Clock Buffer. The compilation is passed. But I always only can access the 2ch on Main PLL, the other 2ch on Clock Buffer PLL can not access.
- Deshi_Intel
HI PHuan32,
It's good to know issue is resolved at your side.
dlim
- PHuan32
Dear dlim,
Thanks! I had solved the issue. The root cause is setting the same parameters of these two PLLs.
Phuan25
- Deshi_Intel
