XQSHEN
4 years agoHow to set timing constraint for differential signal?
For example, clk_p, clk_n
- 4 years ago
Hi Shen,
Only the clock_p of the differential ports needs to be constrained.
If both are constrained, the tool will take them as two separate clock definitions and analyze inter clock paths between them.
This can lead to incorrect requirements.
Similarly, only the P-side of the differential data port needs to be constrained in the input delay and output delay constraints.
The analysis of the clock_n is exactly the same as the clock_p
SyafieqS
4 years agoI’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
