How to set SLOW SLEW RATE in Quartus 17 lite for MAX10 (10M08SCE144C8G)
as explained in device manual
Programmable Output Slew-Rate Control
The programmable output slew-rate control is available for single-ended I/O standards with current strength of 8 mA or higher. You have the option of three settings for programmable slew rate control — 0, 1, and 2 with 2 as the default setting. Setting 0 is the slow slew rate and 2 is the fast slew rate.
• Fast slew-rate—provides high-speed transitions for high-performance systems.
• Slow slew-rate—reduces system noise and crosstalk but adds a nominal delay to the rising and falling edges.
You can specify the slew-rate on a pin-by-pin basis because each I/O pin contains a slew-rate control. The slew-rate control affects both the rising and falling edges.
Thanks for your reply.
I knew about the programmable output slew-rate control feature of MAX10 FPGA but I can't find the option under Quartus 17 Lite.Is something perhaps I have to set under the "Assignement editor" menu?
