9 years agoHow to set automatic values in *.tcl files (automatic maxChannel in my case)
I would like to reuse a custom component with an adjustable channel width parameter (added to the Qsys IP catalog). The problem when using it is that the associated *.tcl file has a static valu...
9 years agoYes, once you edit the hw.tcl file, you can't go back to using the Component Editor because it will overwrite your manual edits.
