14 years agoHow to set a input as fixed binary pattern?
I'm working on a input string, and need to set around 100 bits as input, however, I don't know how to set a input with a fixed pattern, say, "11101001110000......." as input. So, where should set for...
14 years agoso, just to be clear, you are using the MAX2 to generate the test pattern for something else, you're not testing the max2?
