How to set a input as fixed binary pattern?
I'm working on a input string, and need to set around 100 bits as input, however, I don't know how to set a input with a fixed pattern, say, "11101001110000......." as input. So, where should set for this purpose?
Thanks!11 Replies
Kaz, really appreciate for the suggestion. I think I know how to do it now. Thanks a lot!
If I understood you, you need to design a 16 bit shift register as above replacing 64 bits with 16 bits then kick it on every clock edge.
For changing value every 16 clock cycles then simply load new value into shift register. You will need a small counter say 0 ~ 3 to load a specific value at each count. if count 0 load x"...", else if count 1 load x"...." and so on. - Altera_Forum
Thanks, Kaz.
It's the behavior of shift register. I need a 16 bit width. After assigned the initial value and 16 clk cycle passed, I will need another 16 bits input. How to generate the subsequent 16 bits and the following ones? Thanks! Cliff - Altera_Forum
You will need a simple bit generator based on cyclic shift register as Tricky suggested:
i.e. reg started with initial value then on first clock edge it shifts with bit 63 assigned to bit 0, 0 to 1 ...62 to 63 and so on your data is then assign any one or more bits of shift_reg as per data width.-- not tested process(reset,clk) begin if reset = '1' then shift_reg <= x"0123456789ABCDEF"; -- 64 bits initial value elsif rising_edge(clk) then shift_reg <= shift_reg(62 downto 0) & shift_reg(63); end if; end process; - Altera_Forum
Tricky, thanks for the reply.
You mean to connect the inputs of shift registers to either bcc or gnd directly? If it's true, how can I change the input patterns other time cycles? - Altera_Forum
All you need is a shift register that powers up to an initial value and then pumps it out.
Anyone can help me?
Yes, you are right.
Thanks. - Altera_Forum
so, just to be clear, you are using the MAX2 to generate the test pattern for something else, you're not testing the max2?
The purpose is TI generate patterns for simple test. And I use MAXII micro board. So, I have to define input logic of shift register for serial output.
