12 years agohow to run ONLY the assembler step
Hi, I need to run just the assembler step. I'm using older Quartus tools (10.1 sp1) because of IP issues. I did a build early today that finished OK. For some reason later on all the compilation s...
12 years agoThanks. the processing -> start -> start assembler step seems to be running only the assembler. Exactly what I needed. I didn't even know those options existed under processing.
thanks again. JM
