12 years agohow to run ONLY the assembler step
Hi, I need to run just the assembler step. I'm using older Quartus tools (10.1 sp1) because of IP issues. I did a build early today that finished OK. For some reason later on all the compilation s...
12 years agoIn the "Tasks" pane in the left margin, where everything is orange ?, right-click and Start Again.
Except if everything is out of date, I'm pretty sure it's going to re-run the dependencies as well. It sounds like you need to figure out why it's out of date. Also, for updating MIF files specifically, here's how to do it on the command line: http://www.altera.com/support/kdb/solutions/rd12062004_8707.html
