How to resolve timing violations in the accumulator?
My counter has been split into a combination of 2 16-bit counters, ultimately achieving a 32-bit counter. The recommended method by Quartus is to insert a pipeline between different bits of the counter. I think this method is very inconvenient to implement. What are the good solutions?
Time analysis is shown in the figure。
This is the result of post fitting.
- RichardT_altera
I believe your inquiry has been answered. Now, I will transition this thread to community support. If you have any further questions or concerns, please don't hesitate to reach out.
Richard Tan
- RichardT_altera
I believe the suggestion provided by the community have help you improve timing.
Do you need any further assistance in regards to this case?
Richard Tan
- RichardT_altera
Kindly share your design by archiving the project (Project > Archive Project) so that I can investigate it further.
Richard Tan
- student8
Thank you for your response. I'm sorry, but the rest of the code is not my work, and I cannot share it. I can only provide my work, which is the "timedelay" file.
- sstrell
See my reply in your older post. Something is fishy here with your adder.
- _AK6DN_
I agree. The timing report shows at least a nine level CIN/COUT ripple carry chain.
If you want to go for high speed, you need to implement a carry lookahead adder design.
The design as implemented is not going to run very fast due to the implementation.
- student8
Thank you for your reply. The performance has improved after switching to a carry-lookahead adder.
