15 years agoHow to request multiply MSI interrupts?
Hi !!! Developing a network device driver on Arria2 GX (Avalon-ST). Is it possible to set a vector of 8 MSI interrupts , if the design supports only MSI interrupts, not MSI - X? From the...
14 years agoPlease can I get the right revision or originale files which the patch was written for
Because I got the following errors with my fedora 12
# patch -p1 < 0001-Add-support-for-multiple-MSI-on-x86.patch
(Stripping trailing CRs from patch.)
patching file arch/x86/kernel/apic/io_apic.c
Hunk# 1 FAILED at 249.
Hunk# 2 succeeded at 1260 with fuzz 1 (offset 228 lines).
Hunk# 3 FAILED at 1373.
Hunk# 4 FAILED at 2553.
Hunk# 5 FAILED at 3426.
Hunk# 6 FAILED at 3436.
Hunk# 7 FAILED at 3472.
Hunk# 8 FAILED at 3500.
Hunk# 9 FAILED at 3510.
Hunk# 10 FAILED at 3689.
Hunk# 11 FAILED at 3797.
Hunk# 12 FAILED at 3805.
Hunk# 13 FAILED at 3817.
Hunk# 14 FAILED at 3889.
Hunk# 15 FAILED at 3967.
14 out of 15 hunks FAILED -- saving rejects to file arch/x86/kernel/apic/io_apic.c.rej
patching file arch/x86/kernel/hpet.c
Hunk# 1 FAILED at 499.
1 out of 1 hunk FAILED -- saving rejects to file arch/x86/kernel/hpet.c.rej
patching file drivers/pci/htirq.c
Hunk# 1 succeeded at 127 (offset 7 lines).
patching file include/linux/irq.h
Hunk# 1 succeeded at 383 with fuzz 1 (offset 61 lines).
