15 years agoHow to request multiply MSI interrupts?
Hi !!! Developing a network device driver on Arria2 GX (Avalon-ST). Is it possible to set a vector of 8 MSI interrupts , if the design supports only MSI interrupts, not MSI - X? From the...
14 years agoHi,
Thanks for the patch file. but I couldn't executed it and got the following output:
# patch -p0 -i 0001-Add-support-for-multiple-MSI-on-x86.patch
(Stripping trailing CRs from patch.)
can't find file to patch at input line 12
Perhaps you used the wrong -p or --strip option?
The text leading up to this was:
| arch/x86/kernel/apic/io_apic.c | 310 ++++++++++++++++++++++++++++++++++------
| arch/x86/kernel/hpet.c | 2 +-
| drivers/pci/htirq.c | 2 +-
| include/linux/irq.h | 3 +-
| 4 files changed, 271 insertions(+), 46 deletions(-)
|diff --git a/arch/x86/kernel/apic/io_apic.c b/arch/x86/kernel/apic/io_apic.c
|index fadcd74..5e9decc 100644
|--- a/arch/x86/kernel/apic/io_apic.c
|+++ b/arch/x86/kernel/apic/io_apic.c
Line 12 @@ -249,11 +249,6 @@ static struct irq_cfg *alloc_irq_and_cfg_at(unsigned int at, int node)
File to patch:
