15 years agoHow to request multiply MSI interrupts?
Hi !!! Developing a network device driver on Arria2 GX (Avalon-ST). Is it possible to set a vector of 8 MSI interrupts , if the design supports only MSI interrupts, not MSI - X? From the...
14 years agoAdvice: Output based on one msi
# lspci -d 1204:ec30 -v -xxx
04:00.0 Non-VGA unclassified device: Lattice Semiconductor Corporation Device ec30
Subsystem: Lattice Semiconductor Corporation Device 3030
Physical Slot: 3
Flags: bus master, fast devsel, latency 0, IRQ 30
Memory at d0440000 (32-bit, non-prefetchable)
Memory at d0400000 (32-bit, non-prefetchable)
Capabilities: Power Management version 3
Capabilities: MSI: Enable+ Count=1/1 Maskable- 64bit+
Capabilities: Express Endpoint, MSI 00
Capabilities: Device Serial Number 00-00-00-00-00-00-00-00
00: 04 12 30 ec 07 04 10 00 00 00 00 00 10 00 00 00
10: 00 00 44 d0 00 00 40 d0 00 00 00 00 00 00 00 00
20: 00 00 00 00 00 00 00 00 00 00 00 00 04 12 30 30
30: 00 00 00 00 50 00 00 00 00 00 00 00 07 01 00 00
40: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
50: 01 70 03 00 00 00 00 00 00 00 00 00 00 00 00 00
60: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
70: 05 90 81 00 0c 10 e0 fe 00 00 00 00 a9 41 00 00
80: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
90: 10 00 01 00 00 80 00 00 00 00 00 00 11 74 00 00
a0: 00 00 11 00 00 00 00 00 00 00 00 00 00 00 00 00
b0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
c0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
d0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
e0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
f0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
