15 years agoHow to request multiply MSI interrupts?
Hi !!! Developing a network device driver on Arria2 GX (Avalon-ST). Is it possible to set a vector of 8 MSI interrupts , if the design supports only MSI interrupts, not MSI - X? From the...
14 years agoIt seems to be disable by executing the command cat /proc/interrupts
But in the other hand my msi is enabled by the following command lspci -d 1204:ec30 -v -xxx (see output below) ?
# lspci -d 1204:ec30 -v -xxx 04:00.0 Non-VGA unclassified device: Lattice Semiconductor Corporation Device ec30 Subsystem: Lattice Semiconductor Corporation Device 3030 Physical Slot: 3 Flags: bus master, fast devsel, latency 0, IRQ 30 Memory at d0440000 (32-bit, non-prefetchable) Memory at d0400000 (32-bit, non-prefetchable) Capabilities: Power Management version 3 Capabilities: MSI: Enable+ Count=1/1 Maskable- 64bit+ Capabilities: Express Endpoint, MSI 00 Capabilities: Device Serial Number 00-00-00-00-00-00-00-00 00: 04 12 30 ec 07 04 10 00 00 00 00 00 10 00 00 00 10: 00 00 44 d0 00 00 40 d0 00 00 00 00 00 00 00 00 20: 00 00 00 00 00 00 00 00 00 00 00 00 04 12 30 30 30: 00 00 00 00 50 00 00 00 00 00 00 00 07 01 00 00 40: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 50: 01 70 03 00 00 00 00 00 00 00 00 00 00 00 00 00 60: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 70: 05 90 81 00 0c 10 e0 fe 00 00 00 00 a9 41 00 00 80: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 90: 10 00 01 00 00 80 00 00 00 00 00 00 11 74 00 00 a0: 00 00 11 00 00 00 00 00 00 00 00 00 00 00 00 00 b0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 c0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 d0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 e0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 f0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
