19 years agoHow to remove glitches on Incoming signals ?
Hi *, I have signals coming to the FPGA which are not clean . All these signals are asynchronous signals. I want to remove the glitches on these signals and then feed them to the inputs o...
19 years agoHi *,
thanks for some answers. Let me explain the problem in a better way. I have two pcb boards. One contains a processor, and the other contains the FPGA with my design. Now i connect both the PCB's using cables. The processor is sending asynchronous signals to the FPGA. At the moment, i don't have any chance of using any external mechanisms to remove glitches. I would appreciate only solutions, where i can remove the glitches, once the signals enter the FPGA. because these glitches are mostly likely caused by the cables or some noise and so on. Is there anything in Quartus, which tells me that, i don't want any glitches on the input pins, or if they come, they must be suppressed. Regards, Anil
