15 years agohow to read data from the SDRAM to the FPGA
Hello dear developers, buy a DE2 development board for a project. and need to read 960 bits from SDRAM to the FPGA in parallel, but I have not found a way to do this, please if anyone can help than...
15 years ago --- Quote Start --- The data bus isn't 960 bits wide, so you'll have to split it in several reads and combine the results in a big vector. Are you planning to use SOPC builder? --- Quote End --- Thanks for your answer!!!!, I think using SIGNALTAP to debug and verify the operation of the algorithm.
