- GuaBin_N_Intel
Contributor
In general, we would use overconstraint method to tell Fitter putting more priority on specific path during placement. Use "set_max_delay" in SDC as in example here https://fpgawiki.intel.com/wiki/Timing_Constraints to get higher Fmax of a path.
- GuaBin_N_Intel
Contributor
Yes, placement constraint can be made on certain ALM location but there's no method for routing within a path. Find "location" and then set coordination of a register or LAB https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/manual/mnl_qsf_reference.pdf
- GuaBin_N_Intel
Contributor
You can set that specific output register at IO block. It is the fastest and dedicated path connected to IO buffer. Kindly find the setting in assignment editor and follow what had explained here https://www.intel.com/content/www/us/en/programmable/quartushelp/current/index.htm#logicops/logicops/def_output_register.htm
- MTAWA
Thanks GNg, I am familiar with using the assignment editor to place register in the IOB.; I probably used a bad example, but I would like to know how to placement constraint a path, say register to register with critical timing in-between them. Thank you.
- MTAWA
Thanks again GNg, I am familiar with timing constraints and max delay and min delays. I'm looking for placement constraints of a path, similar to floorplanning, but focused on a single path.
- MTAWA
GNg the link provided above is for advanced timing constraints.
