12 years agoHow to measure distance between two data
really i have a problem for measure the distance between these data as the following.could i can make it in vhdl from enter this data to vhdl to measure distance between them. d(s1,s2)=(1+1+0+1+1)...
12 years agofirst you need to have a ram component. You can use inference as below or instantiate altera's ram
it is simple dual (separate read addr/write addr)
library ieee;
use ieee.std_logic_1164.all;
entity wr_rd_ram is
port(
clk : in std_logic;
we : in std_logic;
wr_data : in std_logic_vector(7 downto 0);
wr_addr : in integer range 0 to 255;
rd_addr : in integer range 0 to 255;
rd_data : out std_logic_vector(7 downto 0)
end entity;
architecture rtl of wr_rd_ram is
type mem is array(255 downto 0) of std_logic_vector(7 downto 0);
signal ram : mem;
begin
process(clk)
begin
if(rising_edge(clk)) then
if(we = '1') then
ram(wr_addr) <= wr_data;
end if;
rd_data <= ram(rd_addr);
end if;
end process;
end rtl;
then top level can be something as below. This is not functionally accurate but should give you guidance. You need to simulate and adjust latency issues.
library ieee;
entity test is
port(
rst : in std_logic;
clk : in std_logic;
we : in std_logic;
wr_data1 : in std_logic_vector(7 downto 0);
wr_data2 : in std_logic_vector(7 downto 0);
distance : out integer range 0 to 255;
vout : out std_logic;
no_match : out std_logic
end entity;
architecture rtl of test is
signal rd_data1 : std_logic_vector(7 downto 0);
signal rd_data2 : std_logic_vector(7 downto 0);
signal rd_addr1 : integer range 0 to 255 := 0;
signal rd_addr2 : integer range 0 to 255 := 0;
type states is (s0,s1,s2);
signal state: states;
component wr_rd_ram
port(
clk : in std_logic;
we : in std_logic;
end component;
begin
ram1:wr_rd_ram
port map(
clk => clk,
we => we,
wr_data => wr_data1,
wr_addr => wr_addr,
rd_addr => rd_addr1,
rd_data => rd_data1
ram2:wr_rd_ram
port map(
clk => clk,
we => we,
wr_data => wr_data2,
wr_addr => wr_addr,
rd_addr => rd_addr2,
rd_data => rd_data2
process(rst,clk)
begin
if rst = '1' then
state <= s0;
vout <= '0';
no_match <= '0';
distance <= 0;
elsif rising_edge(clk) then
vout <= '0';
no_match <= '0';
case state is
when s0 =>
rd_addr2 <= rd_addr2 + 1;
if rd_data1 = rd_data2 then
state <= s1;
distance <= rd_addr1 - rd_addr2;
vout <= '1';
elsif rd_addr2 = 255 then
rd_addr2 <= 0;
state <= s2;
end if;
when s1 =>
rd_addr1 <= rd_addr1 + 1;
rd_addr2 <= 0;
state <= s0;
when s2 =>
no_match <= '1';
state <= s0;
when others => null;
end case;
end if;
end process;
end rtl;
