12 years agoHow to measure distance between two data
really i have a problem for measure the distance between these data as the following.could i can make it in vhdl from enter this data to vhdl to measure distance between them. d(s1,s2)=(1+1+0+1+1)...
12 years ago---However you need to read each ram separately
i correct the code to read from each ram,does it is correct?? --and you need distance to be output successively as a stream. how i can do that?? --- you need to read location 0 first and keep it till all locations of ram2 are checked and so on. may i can do that by using function ''='' for equality or std_match (i try to do that) , but it is the correct way?? in the code below library ieee; use ieee.std_logic_1164.all; --use ieee.std_logic_unsigned.all; use IEEE.numeric_std.all; entity test is port ( data_a : in std_logic_vector(7 downto 0); data_b : in std_logic_vector(7 downto 0); addr_a : in std_logic_vector(7 downto 0); addr_b : in std_logic_vector(7 downto 0); we_a : in std_logic := '1'; we_b : in std_logic := '1'; clk : in std_logic; Re_a :in std_logic := '1'; Re_b :in std_logic := '1'; q_a : out std_logic_vector(7 downto 0); q_b : out std_logic_vector(7 downto 0); distance : out std_logic_vector(7 downto 0) ); end test; architecture rtl of test is type memory_t is array(63 downto 0) of std_logic_vector(7 downto 0); signal ram1, ram2 : memory_t; signal read_addr_a : std_logic_vector(7 downto 0); signal read_addr_b : std_logic_vector(7 downto 0); signal q_a_int : std_logic_vector(7 downto 0); signal q_b_int : std_logic_vector(7 downto 0); begin -- Port A ----write to port A process(clk) begin if(clk='1'and clk'event) then if(we_a = '1') then ram1(to_integer(unsigned(addr_a))) <= data_a; end if; read_addr_a <= addr_a; end if; end process; ---read from port A process(clk,Re_a) begin if (Re_a ='1') then q_a_int <= ram1(to_integer(unsigned(read_addr_a))); end if; end process; ------------------------------------------------------- -- Port B --write to port B process(clk) begin if(rising_edge(clk)) then if(we_b = '1') then ram2(to_integer(unsigned(addr_b))) <= data_b; end if; read_addr_b <= addr_b; end if; end process; ---read from port B process(clk,Re_b) begin if (Re_b = '1') then q_b_int <= ram2(to_integer(unsigned(read_addr_b))); end if; end process; ---------------------- process(clk) begin read_addr_a <= X"00"; --reset the address value for reading from memory location "0" process(clk) begin if(rising_edge(clk)) then if (std_match(q_a_int,q_b_int)) then distance <= std_logic_vector(unsigned(addr_a)- unsigned (addr_b)); end if; end if; end process; q_a <= q_a_int; q_b <= q_b_int; end rtl; you also need address to be converted to signed adding sign bit.
