12 years agoHow to measure distance between two data
really i have a problem for measure the distance between these data as the following.could i can make it in vhdl from enter this data to vhdl to measure distance between them. d(s1,s2)=(1+1+0+1+1)...
12 years agosorry, kaz
i tried many times by many ways but it can't be solved what is the mistake,and what is the correct way library ieee; use ieee.std_logic_1164.all; use ieee.std_logic_unsigned.all; use IEEE.numeric_std.all; entity true_dpram_sclk is port ( data_a : in std_logic_vector(7 downto 0); data_b : in std_logic_vector(7 downto 0); addr_a : in std_logic_vector(7 downto 0); addr_b : in std_logic_vector(7 downto 0); we_a : in std_logic := '1'; we_b : in std_logic := '1'; clk : in std_logic; q_a : out std_logic_vector(7 downto 0); q_b : out std_logic_vector(7 downto 0); distance: out std_logic_vector(7 downto 0) ); end true_dpram_sclk; architecture rtl of true_dpram_sclk is -- Build a 2-D array type for the RAM subtype word_t is std_logic_vector(7 downto 0); type memory_t is array(63 downto 0) of word_t; -- Declare the RAM shared variable ram : memory_t; signal a_output:std_logic_vector(7 downto 0 ); signal b_output:std_logic_vector(7 downto 0); signal d :std_logic_vector(0 to 7); begin -- Port A process(clk) begin if(rising_edge(clk)) then if(we_a = '1') then ram(conv_integer (addr_a)) := data_a; end if; a_output <= ram(conv_integer (addr_a)); end if; q_a <= a_output; end process; -- Port B process(clk) begin if(rising_edge(clk)) then if(we_b = '1') then ram(conv_integer (addr_b)) := data_b; end if; b_output <= ram(conv_integer (addr_b)); end if; q_b <= b_output; if (std_match(a_output(0),b_output(0) )) then d<= std_logic_vector(signed(addr_a(0))- signed (addr_b(0))); -----error The expression can not be converted to type signed. end if; distance <= d; end process; end rtl;
