13 years ago
How to make bidirectional bus in SystemVerilog
I have a bidirectional 8 bit bus for communicating between my CPLD and my main CPU. At the top level module I declared this like this (left out details of other IO stuff):
module top ( inout [7:0] gpbus, input bit rd, input bit wr );
When I drive the gpbus from my test bench it works fine. When I set the gpbus to 8'bZ it does tri-state it. However, when I drive it from inside my module nothing changes at the test bench. It stays tri-stated.
How do I correctly create and connect such a bus and simulate it? I've tried using the alias statement but no matter what I do that creates an error "near text 'alias' expecting endmodule".
    No, you are not off base. I don't know your design intent. If the real hardware depends on delays to operate, you need to account for it in your model, either with proper delays, or choosing the correct abstraction.
