12 years agoHow to let FPGA get access to HPS pins
I've got an Arrow SOCkit and it has a USB-UART connected to the HPS' pins, but I'd like to access the UART from the FPGA logic. Is this possible? If so how is it done? Thank you!
SanaGuezguez
6 years agoHello everyone,
I'm having an issue implementing an FPGA to HPS communication and vice versa. I'm using the MitySOM 5csx with a Cyclone V SoC. The purpose of the project is to setup the bridges between the HPS and FPGA in such a way that a program running on the HPS will send data to the FPGA which will process it and return a result. I've generated a QSYS design, composed by the HPS (with Cyclone V settings), two fifos, a clock bridge, a clock and an SDRAM.
When I run the simulation and synthesis and the TCL pin-assignment script generated by Qsys everything works fine. The issue comes when I try to compile the whole design, because I get an error message saying there are 375 IO input pads in the design, but only 331 IO input pad locations are available on the device. I don't know what I'm missing or doing wrong. Any suggestion is welcome
